[PIC] PIC16F1827 and SHTxx, problem when read the value(not change)
truong_giang2211
Junior Member level 1
tphcm
Hi everyone,
I am newer.
As below is my code+hex file and simulate circuit in Protues7.8. I am using CCS V5.xx
I finished my project when i use PIC16f877a.
But when i copy code(i just changed PIN DATA and SCK), it can work, but the value of temperature not change(update) ? Reason why ??
Thanks for your read !
My code:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
#include <16F1827.h>
//#DEVICE ADC=8
#include <stdio.h>
#include <math.h>
#FUSES NOWDT, HS, NOPUT, PROTECT, NODEBUG, NOBROWNOUT, NOLVP
#use delay(clock = 4000000)
#USE RS232(baud=2400, xmit=PIN_B5, rcv=PIN_B2)
#define sht_data_pin   PIN_B7
#define sht_clk_pin    PIN_B6
#define LED    PIN_B0
#define LED1   PIN_B3
void comstart (void)
    output_float(sht_data_pin);  //data high
    output_bit(sht_clk_pin, 0);  //clk low
    delay_us(1);
    output_bit(sht_clk_pin, 1);  //clk high
    delay_us(1);
    output_bit(sht_data_pin, 0); //data low
    delay_us(1);
    delay_us(2);
    delay_us(1);
    delay_us(1);
// write data to SHT75
int1 comwrite (int8 iobyte)
    int8 i, mask = 0x80;
    int1 ack;
    //Shift out command
    delay_us(4);
    for(i=0; i<8; i++)
      if((iobyte & mask) > 0) output_float(sht_data_pin);  //data high if MSB high
      else output_bit(sht_data_pin, 0);                    //data low if MSB low
      delay_us(1);
      delay_us(1);
      mask = mask >> 1;                                    //shift to next bit
    //Shift in ack
    delay_us(1);
    ack = input(sht_data_pin);   //get ack bit
    delay_us(1);
    return(ack);
// read data from SHT75
int16 comread (void)
    int8 i;
    int16 iobyte = 0;
    const int16 mask0 = 0x0000;
    const int16 mask1 = 0x0001;
    //shift in MSB data
    for(i=0; i<8; i++)
      iobyte = iobyte << 1;
      delay_us(1);
      if (input(sht_data_pin)) iobyte |= mask1;  //shift in data bit
      else iobyte |= mask0;
      delay_us(1);
    //send ack 0 bit
    delay_us(1);
    delay_us(2);
    delay_us(1);
    //shift in LSB data
    for(i=0; i<8; i++)
      delay_us(1);
      delay_us(1);
    //send ack 1 bit
    delay_us(1);
    delay_us(2);
    return(iobyte);
//***** Function to wait for SHT75 reading *****
void comwait (void)
    int16 sht_delay;
    delay_us(1);
    for(sht_delay=0; sht_delay<30000; sht_delay++)  // wait for max 300ms
         if (!input(sht_data_pin)) break;              //if sht_data_pin low, SHT75 ready
         delay_us(10);
// reset SHT75 communication
void comreset (void)
    int8 i;
    delay_us(2);
    for(i=0; i<9; i++)
         output_bit(sht_clk_pin, 1);  //toggle clk 9 times
         delay_us(2);
         delay_us(2);
    comstart();
//***** Function to soft reset SHT75 *****
void sht_soft_reset (void)
    comreset();           //SHT75 communication reset
    comwrite(0x1e);       //send SHT75 reset command
    delay_ms(15);         //pause 15 ms
//***** Function to measure SHT75 temperature *****
int16 measuretemp (void)
    int1 ack;
    int16 iobyte;
    comstart();             //alert SHT75
    ack = comwrite(0x03);   //send measure temp command and read ack status
    if(ack == 1) return;
    comwait();              //wait for SHT75 measurement to complete
    iobyte = comread();     //read SHT75 temp data
    return(iobyte);
//***** Function to measure SHT75 RH *****
int16 measurehumid (void)
    int1 ack;
    int16 iobyte;
    comstart();            //say to SHT75
    ack = comwrite(0x05);  //send measure RH command and read ack status
    return(iobyte);
//calculate SHT75 temp & RH
void calculate_data (int16 temp, int16 humid, float & tc, float & rhlin, float & rhtrue)
    float  rh;
    //float truehumid1;
    //calculate temperature reading
    tc = ((float) temp * 0.01) - 40.0;
    //calculate Real RH reading
    rh = (float) humid;
   // rh linear
    rhlin = (rh * 0.0405) - (rh * rh * 0.0000028) - 4.0;
    //calculate True RH reading
    rhtrue = ((tc - 25.0) * (0.01 + (0.00008 * rh))) + rhlin;
//***** Function to measure & calculate SHT75 temp & RH *****
void sht_rd (float & temp, float & truehumid)
    int16 restemp, reshumid;
    float realhumid;
    restemp = 0; truehumid = 0;
    restemp = measuretemp();    //measure temp
    reshumid = measurehumid();  //measure RH
    calculate_data (restemp, reshumid, temp, realhumid, truehumid);  //calculate temp & RH
//***** Function to initialise SHT75 on power-up *****
void sht_init (void)
    comreset();    //reset SHT75
    delay_ms(20);  //delay for power-up
void main(void)
    float restemp, truehumid;
    sht_init();
    delay_ms(200);
    long a[30]={0x00,0xff,0xff,0x00,0x05,0x06,0x07,0x08,0x09,0x0A,0x0B};
   // int so1=0,so2=0;
    while(TRUE)
       delay_ms(100);
       sht_rd (restemp, truehumid);
       a[4]= restemp;
       putc(restemp);
       delay_ms(500);
       output_toggle(LED);
     delay_ms(200);        //delay 200 ms between reading to prevent self heating of sensor
  • 16f1827.rar
1> while conversion process in adc the chip must be disselected .
2>after conversion the clk signal must be low to fetch the converted data
3> after this the chip is deselected and step 1 is repeated again
in this way ur temperature sensor data will be updated
There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle.
Dear Tanmay Dash,
Thanks for your answer.
According datasheet, SHTxx provide digital interface with MCU, no need ADC module. So in this case, i dont use ADC to convert signal into digital as you think.
In here MCU send clock to SHTxx and then SHTxx will receive and feedback to MCU.
File attach is datasheet of SHTxx sensor.
  • Sensirion_Humidity_SHT7x_Datasheet_V5.pdf
dear truang,
after going trhrough the document that u have attached(shtxx) i came to know the following things.plz check that if u have implement the things in ur program--
1 > after start up shtxx takes 11ms .so provide a delay of 11ms
2> then u have to start communication by initiating transmission sequence-make clk line high then lower the dataline, followed by pulling low clock line and then raising the data line.
3> after the 8bit rception the acknowledgement is given by the shtxx by lowering the data..plz check the ack
4> after sucessful ack....user should make the data line high at 9th clk pulse
in this way u can get ur output..
The happiest of people don’t necessarily have the best of everything they just make the most of everything that comes along their way.
