OsirisB
Newbie level 2
- Joined
- Nov 27, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 22
Hi Guys,
I have just joined this forum and am in need of some help.
>>I am building a project using the PIC12F683 to read in a 10V pulse *refer attachment for pulse
>> The program needs to read the number of pulses for a second, then multiply that by 60 to get rpm.
>>If then checks the condition of a variable (Temp).
>> If Temp=0 and rpm>300, then the pic will set a pin output to ground for a second.
>>Another condition (seperate from the previous) also monitors another pin to check if it has been set to ground, and then sets Temp=0.
>> The pic needs to reset everytime power is switched off and on.
>> Please note that pins GP1 and GP0 running condition is not HIGH or LOW, but no connection.
>> I have attached my code *please be gentle :-D
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 /* PIC12f683 Clock set to 4Mhz */ unsigned int temp, PulseCount,rpm; void main() { CMCON0 = 7; // Disable comparators // 543210 TRISIO = 0b00100010; // GP1 --> Recieves GND Input from tact switch, GP5 --> 10V Pulse input for counting // GP0 --> Pin set to GND when conditions are met ANSEL = 0x00; // No analog inputs GPIO=0; PIE1 = 0b00000001 ; // Enable TMR1IE temp=0; Pulsecount=0; rpm=0; do { TMR1H = 0x00; TMR1L = 0x00; T1CON = 0b00000111; // Enable Timer 1 Delay_ms(1000); T1CON = 0b00000110; // Disable Timer 1 PulseCount = TMR1H; rpm= Pulsecount*60; //converts revolutions per second to revolutions per minute IF((rpm > 300) && (temp = 0)) { GPIO.GP0=0; //set the GP0 output from no connection to GND Temp=1;} //tracks the condition of pin GP0 IF (GPIO.GP1=0) {//Checks if GP1 recieved GND input from no connection Temp=0;} } while(1); }
