Hi again, with a 2 or more channel chip (like FT2232H or FT4232H) how can you set what channel will be active to the usb at a time..? E.g one channel is used to get the sample data from PIC to PC and from the other channel i want to send a command to PIC. How the command will be inserted into the USB bus as the other channel uses it..?
For sure, otherwise it makes no sense....So within the D2XX library can i chose to with channel i want to write?
