Gonzoid
Newbie level 3
Hello Everyone,
I have previously created a source code that implements a 4x3 keypad and an LCD display. The idea was to have the circuit act much like a keyboard, where whatever key is pressed on the keypad is displayed on the LCD. However, when add to the hardware, the LCD would receive information from 6 of the 12 keypad buttons. The keypad routine I used I simply had copy and pasted from another source file, with a few modifications, I had made to drive LED's, and it had worked. The LCD routine I also simply copy and pasted from a source file I had made, which only displayed one message.
Here is my combined source code, in Assembly:
I have change the characters in the LCD Lookup table so that the ones blank and in parenthesis are the locations in the program that don't work, and the lettered values are the locations in the program that do display in the LCD. I have bolded this section for quick reference. I am using a PIC 16F877a microcontroller, editing using MPLAB, with 4x3 keypad and 16 pin LCD. If anyone can see any issues with my coding, please let me know.
#include <P16F877A.INC> ;Header File
KEY EQU 0X20 ;This is the user defined DRAM area that
COUNT EQU 0X21 ; uses the 68 bytes GPR: range from 0X0C-0X4F
MEM EQU 0X22
TEMP EQU 0X23
TEMP2 EQU 0X24
DVAR EQU 0X25
FLAG EQU 0X26
TEMP_3 EQU 0X27
TEMP_4 EQU 0X28
SAVE EQU 0X29
INDEX EQU 0X2A
COUNT2 EQU 0X2B
COUNT3 EQU 0X2C
__CONFIG 0X3F72 ;This is the control bits for CONFIG register
ORG 0X0000 ;RESET or WDT reset vector
GOTO START
ORG 0X0004 ;Regular INT vector
;This is the area where your interrupt service routine goes
RETFIE
INIT
BSF PORTD,0 ;Set E line High
BCF PORTD,1 ;Set RS line low
MOVLW 0X30
MOVWF PORTC ;Put initialization value into LCD
CALL TOGGLE_E ;Short delay
CALL DELAY ;20 ms delay
MOVLW 0X30
MOVLW 0X30
MOVLW 0X38
MOVLW 0X0C
MOVLW 0X01
MOVLW 0X06
MOVLW 0X02
BSF PORTD,1 ;Resets RS line
RETURN ;Returns to main program
DELAY
MOVLW 0X4A ;Set X (LOOP1) to 74 count
MOVWF COUNT ;Moves 0X4A into Counter 1
LOOP1
MOVLW 0XFC ;Set Y (LOOP2) to 252 count
MOVWF COUNT2 ;Moves 0XFC into Counter 2
LOOP2
DECF COUNT2,F ;Decrease counter 2
BTFSS STATUS,Z ;Bit check counter 2
GOTO LOOP2 ;Restart loop 2
DECF COUNT,F ;Decrease counter 1
BTFSS STATUS,Z ;Bit test counter 1
GOTO LOOP1 ;Restart loop 1
RETURN ;Returns from subroutine 1
TOGGLE_E
BCF PORTD,0 ;Clear E line
NOP
NOP
NOP
RETURN ;Return
CHK_KEY
MOVLW 0X04 ;Set Count3 to 0X04
MOVWF COUNT3
MOVF PORTB,W ;Moves input from keypad into W
MOVWF TEMP_4 ;Save W in Temp_4
ROTATE
RRF TEMP_4,F ;Rotates Temp_4 right
BTFSS STATUS,C ;Checks for carry from rotate
CALL MOOP ;Calls MOOP subroutine
INCF INDEX,F ;Increments Index by 1
DECFSZ COUNT3,F ;Decreases counter until 0
GOTO ROTATE ;Restarts rotate subroutine
MOOP
MOVF INDEX,W ;Moves Index into W
MOVWF SAVE ;Saves Index
CALL DEBOUNCE ;Cakk debounce subroutine
BSF FLAG,0 ;Sets Flag to 0
RETURN ;Returns to Rotate
DEBOUNCE
MOVF PORTB,W ;Moves input from PortB into W
MOVWF TEMP_3 ;Saves in Temp_3
RRF TEMP_3,F ;Rotates Temp_3 Right
BTFSS STATUS,C ;Tests C for set
GOTO DEBOUNCE ;Restarts Debounce routine
BSF FLAG,0 ;Set Flag 0
RETURN ;Returns to MOOP routine.
[B]LN_TABLE ;LCD Reference Table[/B]
MOVWF TEMP2 ;Save W in TEMP2
MOVLW HIGH MSG ;Reference high message
MOVWF PCLATH ;Update the PCH register
MOVF TEMP2,W ;Get LO byte
ADDLW LOW MSG ;Update PCL register
BTFSC STATUS,C ;Check for overflows
INCF PCLATH,F ;Update overflow of PCH
MOVWF PCL
[B]MSG ;Letters for LCD Display
ADDWF PCL,F
RETLW ' '
RETLW ' '
RETLW ' '
RETLW 'A' ;Works
RETLW 'B' ;Works
RETLW 'C' ;Works
RETLW ' '
RETLW 'D' ;Works
RETLW 'E' ;Works
RETLW 'F' ;Works[/B]
RETLW 0X00 ;Signature
START ;The starting place of the user codes
;This is the area where your main program that is the major routine and
; subroutine in the Assembly language format goes
CLRF FLAG
BSF STATUS,RP0 ;Set to Bank 1
MOVLW 0X0F
MOVWF TRISB ;Moves 0X0F into TRISB (PORTB)
MOVLW 0X00
MOVWF TRISA ;Moves 0X00 into TRISA (PORTA)
MOVLW 0X00
MOVWF TRISC
MOVLW 0X80
MOVWF TRISD
BCF STATUS,RP0
BCF PORTD,1 ;Clear RS for initialization
CALL INIT ;Run initialization
KEY_LOOP
BTFSS PORTD,7
CALL LOCK
CLRF FLAG
CALL DELAY
CALL DELAY
MOVLW 0X00
MOVWF INDEX
BCF PORTB,7
BSF PORTB,6
BSF PORTB,5
CALL CHK_KEY
BTFSC FLAG,0
GOTO CLICK
BCF PORTB,6
BSF PORTB,7
BSF PORTB,5
CALL CHK_KEY
BTFSC FLAG,0
GOTO CLICK
BCF PORTB,5
BSF PORTB,7
BSF PORTB,6
CALL CHK_KEY
BTFSC FLAG,0
GOTO CLICK
GOTO KEY_LOOP
CLICK
CLRW
MOVWF TEMP ;Save in TEMP
DISPLAY_LONG
MOVF TEMP,W
INCF TEMP,F
CLEAR
CLRF FLAG
CLRF PORTC
MOVF SAVE,W
CALL LN_TABLE ;Calls long table
MOVWF PORTC ;Sets message to Port C
IORLW 0X00 ;OR message
BTFSC STATUS,Z ;Check for zero
GOTO $ ;End program
CALL DELAY ;20ms delay
GOTO KEY_LOOP ;Restart loop
LOCK
BTFSS PORTD,7
GOTO CLEARED
RETURN
STOP
GOTO $
END
