lunar
Junior Member level 2
pic interrupts
Hello i am using PIC18F4550 and i want to use its interrupts, i have written a simple code to blink an led when interrupt is received on RB0. But its not working please see the code and guide.
thanks
thanks
//test code for int0, blink led on portD on receving interrupt
#include <p18f4450.h>
void main (void);
void InterruptHandlerHigh (void);
void main ()
int i=0;
INTCON2bits.INTEDG0=1;//m interrupt is rising edge
INTCONbits.INT0IE=1;//m enable interrupt
INTCONbits.GIEH = 1; //enable global interrupts
TRISB = 1; //set port b as input
TRISD=0; //set port d as output
while(1);//move in loop, gets out on receving interrupt and then comes back.
}//end main
// High priority interrupt vector
#pragma code InterruptVectorHigh = 0x08
void
InterruptVectorHigh (void)
_asm
goto InterruptHandlerHigh //jump to interrupt routine
_endasm
// High priority interrupt routine
#pragma code
#pragma interrupt InterruptHandlerHigh
void
InterruptHandlerHigh ()
{ int i=0;
int j=0;
if (INTCONbits.INT0F)
INTCONbits.INT0IE=0;//m disable the interrupt
for(j=0;j<4;j++)//toggle the bit0 or portD on receiving interrupt
LATDbits.LATD0 = 1;
for( i=0;i<40000;i++);
LATDbits.LATD0 = 0;
INTCONbits.INT0F=0; //m reset the flag
INTCONbits.INT0IE=1;//m enable the interrupt
