PIC ic and PCF8583 Clock chip.
The Puma
Full Member level 2
pcf8583 mikroc
How can i read the time and date from this chip.
Day month and year??
I have CCS-C
Did anyone have sample code to do this.
I have this code so far
#include <18F4620.h>
#use delay(clock=20000000)
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
#include <flex_lcd420.h>
#include <pcf8583.h>
void main() {
	lcd_init();
	while(TRUE) {
		Gettime();
		lcd_gotoxy(1,1);
		printf(lcd_putc,"Time: %01u%01u:%01u%01u:%01u%01u",time[4],time[5],time[2],time[3],time[0],time[1]);
#ifndef PCF8583_SDA
#define PCF8583_SDA PIN_C4
#define PCF8583_SCL PIN_C3
#endif
#use i2c(master,sda=PCF8583_SDA,scl=PCF8583_SCL,FORCE_HW,RESTART_WDT)
// Defines address for Read and Write ON I2C BUS
#define PCF8583_ADDR_WRITE      0xA0
#define PCF8583_ADDR_READ       0xA1
// Defines internal registers
#define CONTROL_STATUS_REG      0x00
#define HUNDREDTH_OF_SEC_REG    0x01
#define SECONDS_REG             0x02
#define MINUTES_REG             0x03
#define HOURS_REG               0x04
#define YEAR_DATE_REG           0x05
#define WEEKDAYS_MONTHS_REG     0x06
#define TIMER_REG               0x07
#define ALARM_CONTROL_REG       0x08
#define ALARM_HUNDREDTH_OF_SEC  0x09
#define ALARM_SECONDS           0x0A
#define ALARM_MINUTES           0x0B
#define ALARM_HOURS             0x0C
#define ALARM_DATE              0x0D
#define ALARM_MONTH             0x0E
#define ALARM_TIMER             0x0F
#define FREE_RAM_START          0x10
#define FREE_RAM_END            0xFF
// Defines Control/Status Register (RESET STATE: 0000 0000)
typedef struct {
    byte TIMER_FLAG     :1;     // 50% duty factor seconds flag if ALARM_ENABLE bit is 0
    byte ALARM_FLAG     :1;     // 50% duty factor minutes flag if ALARM_ENABLE bit is 0
    byte ALARM_ENABLE   :1;     // 0 -> alarm disabled, 1 -> enable alarm
    byte MASK_FLAG      :1;     // 0 -> read locations 05 to 06 unmasked, 1 -> read date and month count directly
    byte FUNCTION_MODE  :2;     // 00 -> clock mode 32.768 kHz, 01 -> clock mode 50 Hz, 10 -> event-counter mode, 11 -> test modes
    byte HOLD_COUNT     :1;     // 0 -> count, 1 -> store and hold last count in capture latches
    byte STOP_COUNT     :1;     // 0 -> count pulses, 1 -> stop counting, reset divider
} CTRLSTATUSREG;
// <CtrlStatusReg> bit settings
// Alarm enable bit settings
#define ALARM_OFF               0x00
#define ALARM_ON                0x01
// Mask flag settings
#define MASK_FLAG_OFF           0x00
#define MASK_FLAG_ON            0x01
// Function mode settings
#define CLOCK_32_768KHZ         0x00
#define CLOCK_50HZ              0x01
#define EVENT_COUNTER           0x02
#define TEST_MODES              0x03
// Hold last count settings
#define COUNT                   0x00
#define STORE_HOLD_LAST_COUNT   0x01
// Stop count settings
#define COUNT_PULSES            0x00
#define STOP_COUNTING           0x01
// Used in 'byte PCF8583_Counter(byte Status)'
#define COUNTER_OFF             0x00
#define COUNTER_ON              0x01
// Defines seconds register (RESET STATE: ???? ????)
struct {
    byte UNITS_BCD      :4;     // Unit seconds BCD format
    byte TENS           :3;     // Ten seconds, 0 to 5 binary
    byte NOT_UNUSED     :1;     // NOT USED
} SECONDSREG;
// Defines minutes register (RESET STATE: ???? ????)
struct {
    byte UNITS_BCD      :4;     // Unit minutes BCD format
    byte TENS           :3;     // Ten minutes, 0 to 5 binary
} MINUTESREG;
// Defines hours register (RESET STATE: 0000 0000)
struct {
    byte UNITS_BCD      :4;     // Unit hours BCD format
    byte TENS           :2;     // Ten hours, 0 to 2 binary
    byte AM_PM_FLAG     :1;     // 0 -> AM, 1 -> PM
    byte FORMAT         :1;     // 0 -> 24h format, 1 -> 12h format
} HOURSREG;
// Defines yeardate register (RESET STATE: 0000 0001)
struct {
    byte UNIT_DAYS_BCD  :4;     // Unit days BCD format
    byte TEN_DAYS       :2;     // Ten days, 0 to 3 binary
    byte YEAR           :2;     // 0 to 3 binary, reads as 0 if the mask flag is set
} YEARDATEREG;
// Defines weekdaysmonths register (RESET STATE: 0000 0001)
struct {
    byte UNIT_MONTHS_BCD:4;     // Unit months BCD format
    byte TEN_MONTHS     :1;     // Ten months
    byte WEEKDAYS       :3;     // Weekdays, 0 to 6 binary, reads as 0 if mask flag is set
} WEEKDAYSMONTHS;
// Defines Alarm control register, clock mode (RESET STATE: 0000 0000)
typedef struct {
    byte TIMER_FUNCTION         :3;  // 000 -> timer, 001 -> hundr.of seconds, 010 -> seconds, 011 -> minutes, 100 -> hours, 101 -> days
    byte TIMER_INTERRUPT_ENABLE :1;  // 0 -> timer flag (no interrupt), 1 -> timer flag (interrupt)
    byte CLOCK_ALARM_FUNCTION   :2;  // 00 -> no alarm clock, 01 -> daily alarm, 10 -> weekday alarm 11 -> dated alarm
    byte TIMER_ALARM_ENABLE     :1;  // 0 -> no timer alarm, 1 -> timer alarm
    byte ALARM_INTERRUPT_ENABLE :1;  // 0 -> alarm flag (no interrupt), 1 -> alarm flag (interrupt)
} ALARMCTRLREG;
// <AlarmCtrlReg> bit settings
// Timer Function settings
#define NO_TIMER                0x00
#define HUNDREDTHS_OF_SECONDS   0x01
#define SECONDS                 0x02
#define MINUTES                 0x03
#define HOURS                   0x04
#define DAYS                    0x05
// Timer Interrupt settings
#define TIMER_FLAG_NO_INTERRUPT 0x00
#define TIMER_FLAG_INTERRUPT    0x01
// Clock Alarm Function settings
#define NO_CLOCK_ALARM          0x00
#define DAILY_ALARM             0x01
#define WEEKDAY_ALARM           0x02
#define DATED_ALARM             0x03
// Timer Alarm Enable settings
#define NO_TIMER_ALARM          0x00
#define TIMER_ALARM             0x01
// Alarm Interrupt Enable settings
#define ALARM_FLAG_NO_INTERRUPT 0x00
#define ALARM_FLAG_INTERRUPT    0x01
// Alarm WeekDays settings
#define SUNDAY                  0x01
#define MONDAY                  0x02
#define TUESDAY                 0x04
#define WEDNESDAY               0x08
#define THURSDAY                0x10
#define FRIDAY                  0x20
#define SATURDAY                0x40
byte time[6];
byte decD2hexD(byte value) {
	return(value%10+16*(value/10));
byte hexD2decD(byte value) {
	return(value%16+10*(value/16));
byte pcf8583_read(byte address) {
	byte data;
	i2c_start();
	i2c_write(PCF8583_ADDR_WRITE);
	i2c_write(address);
	i2c_start();
	i2c_write(PCF8583_ADDR_READ);
	data=i2c_read(0);
	i2c_stop();
	return(data);
void Gettime() {
	SECONDSREG=pcf8583_read(SECONDS_REG);
	MINUTESREG=pcf8583_read(MINUTES_REG);
	HOURSREG=pcf8583_read(HOURS_REG);
	time[0]=hexd2decD(SECONDSREG.TENS);
	time[1]=hexd2decD(SECONDSREG.UNITS_BCD);
	time[2]=hexd2decD(MINUTESREG.TENS);
	time[3]=hexd2decD(MINUTESREG.UNITS_BCD);
	time[4]=hexd2decD(HOURSREG.TENS);
	time[5]=hexd2decD(HOURSREG.UNITS_BCD);
pcf8583 pic
Mikroelekronika's MikroC has example about this chip. It isn't CCS-C, I know, but you may get some idea.
