Finding the max efficiency point is quite easy:
* make sure low power input is set to full power
* start with psu voltage a few volts higher than the rated motor voltage
* run the motor at a typical speed
* using a variable psu and amp meter;
* slowly reduce the voltage until the amps drop suddenly
* the voltage JUST before the amps drop is the max efficiency (min heat)
