;Date: Nov. 17, 2010 ;
;Version: 0.0.3 ;
;Title: EE395_PROJ ;
;Description: This program will ;
;combinethe bluetooth module and ;
;pic16f886 to form a transimitter ; ;
include "P16f886.inc"
;list p=16f886
;__config 0x02f5 ;remember that config can also set not in code
;*****************************************************pins layout**********************************************************
;RC1 = right turn request
;RC0 = left turn request
;RA1 = right turn led
;RA0 = left turn led
;RC7 = RX
;RC6 = TX
;*****************************************************Constant Declarations************************************************
DATA_OUT equ h'21' ;for recording the value of input PORTA
;DATA_IN equ h'22' ;for recording the value of
ERR equ h'23' ;for error checking in receiving data (UART module)
COUNT equ h'24';
N equ d'249'
#define BAUD d'9600' ;baud rate is 9600
#define XTAL d'4' ;4MHz clock as its default
#define X ((XTAL*d'1000000')/(d'64'*BAUD))-1 ;which is 5, baud rate now is 10416 and SPBRG=5
;*****************************************************initialization********************************************************
org h'00'
goto start
org h'04'
goto ISR
;***Set Up Ports***
start
BANKSEL ANSELH
CLRF ANSELH
BANKSEL TRISB ;
MOVLW B'00000011' ;set RC0, RC1 as input, other as outputs
MOVWF TRISB
BANKSEL PORTB ;
CLRF PORTB ;Init PORTC
BANKSEL ANSEL ;
CLRF ANSEL ;digital I/O
BANKSEL TRISA ;
MOVLW B'00000000';et RA0, RA1 as output
MOVWF TRISA
BANKSEL PORTA ;
CLRF PORTA ;Init PORTA
BANKSEL TRISC
MOVLW b'10000000' ;make PORTC RC7/RX(input), RC6/TX(output)
MOVWF TRISC
BANKSEL PORTC
CLRF PORTC
;***initialize the oscillator***
BANKSEL OSCCON
MOVLW b'01101000'
MOVWF OSCCON
;***initialize the uart***
BANKSEL SPBRG
MOVLW B'00000101'
MOVWF SPBRG
;BRGH default 0
;BRG16 default 0, 8 bit generator
;so baud rate is 10416 now
;SYNC default 0, asychrnous
BANKSEL RCSTA
BSF RCSTA, SPEN ;SPEN set, (configures RX/DT and TX/CK pins as serial port pins)
BSF RCSTA, CREN
;RX9 default 0, 8 bit transmittion
BANKSEL TXSTA
BSF TXSTA, TXEN ;transmit enabled
;***initialize interrupt***
BANKSEL PIE1
BSF PIE1, TXIE ;tx interrupt enable
BANKSEL INTCON ;enable external interrupt
BSF INTCON, PEIE
;BSF INTCON, RBIE
BSF INTCON, GIE ;enable global interrupt
;BANKSEL IOCB
;BSF IOCB, IOCB0
;BSF IOCB, IOCB1
;*****************************************************main program**********************************************************
;light up left or right led when left or right request comes
main
;***led control***
bcf STATUS ,RP1
bcf STATUS ,RP0
clrf PORTB
; bsf INTCON, RBIE
;bcf INTCON, RBIF
;loop
donothing
nop
loop
btfss PIR1, TXIF
goto loop
movf PORTB,w ;read the request from PORTA, 0 = w
movwf DATA_OUT
movwf TXREG
goto donothing ;here is tricky, the ISR failed, who knows why?
org 0x80
ISR
movf DATA_OUT, w
movwf PORTA
call DELAY_100ms
;bcf INTCON, RBIF
;bcf INTCON, INTF
bcf PIR1, TXIF
clrf PORTB
clrf PORTA
retfie
DELAY_100ms
movlw d'100'
movwf COUNT
DELAY_1ms
movlw N
D_LOOP
addlw -1
btfss STATUS, Z
goto D_LOOP
decfsz COUNT, f
goto DELAY_1ms
return
end
//the above are my codes, and I enabled TXIF this time, inoder to see whether a transmission is completed.
