Hi linhnc308 you can not speed up the motor with a higher supply voltage, you have to send your data faster or change to larger steps, a higher supply voltage can only damage your components or your stepper motor, it is the frequency of the data that determine the speed of the motor, but you can send the data to fast for the motor to keep up.linhnc308 said:I'm using 4 FET IRF540 for Stepmotor driver, it run good, for speed up, you can increase the supply voltage
