pic 16f877 with keypad
PA3040
Advanced Member level 3
Dear all
please advice me how may I scan and recognize witch number press from
the key board ( 0 to 9 ) connected to portb
my most prefer language is assembly
Dear all can we use A/D converter to recognised the key in key pad
that mean, each keys has unique resistance
can somebody explain it more
thanks in advance
See this Microchip pdf, tip #7.
https://ww1.microchip.com/downloads/en/devicedoc/40040b.pdf
Basically the resistors to each key form a potential divider from the 5V supply to the adc i/o pin.
You carefully select the values to create an suitably spaced voltage for the 16 keys across the 5v range, so when you read the keys voltage into a ADC port you can work out which key was pressed.
When selecting your resistors ensure you have a total of at least 2k for any key otherwise you will risk shorting out the +5v rail.
Electronics 2000 | Potential Divider Calculator
Reactions: PA3040
    PA3040
Dear wp100
Thanks for reply
as per this method, if resister or supply voltage will changed how MCU recognise actual key
It would take too long to explain it all here.
You first need to do some basic tests with a simple adc routine using a 10k pot as the input source, so you understand how it works, then the answer for you keypad should become clear.
Have a look at that Winpicprog ADC tutorial which gives a good description of the software.
However his extra ADC input hardware is not needed for a simple voltage test, just feed the 10k pots slider directly to the adc pin.
Also see this sites ADC lesson
Dear All
what is the most precise method to recognize a key in the key pad in between AD converter and
PORTB change( interrupted ) methods
Thanks in advance
Dear all
if we configure portb as input
then we
movlw 0xff
movwf portb
and then read the port
movf portb,w
movwf result ; result register
so in MPLAB SIM result is
result = 0x00
but anther simulator (PIC SIMULATOR IDE) result is 0xff
PLEASE ADVICE
To set the Port to Input or Output you use the TRIS instruction.
banksel TRISB
movlw 0xFF
movwf TRISB
banksel PORTB
movf PORTB,W
