[SOLVED] pic 16f84 f serial programmer
thannara123
Advanced Member level 5
India
sie i am new in pic programming ,i have lot of circuits to program and i did but i cant burn it becuase a problem erase at the time of varifing it sown failed at 0000h location
my serial port (DB9)is i pci /isa (externaly )
pls give any circuits to program by USB
or what is the reason
thanks
thannara123@gmail.com
If you plan to continue developing using Microchip PIC line-up microcontrollers, then it would be best for you to buy a PICKit2 / PICKit3. I use a PICKit2, very good, can't say much about PICKit3.
You may try PICkit2 clone which is excellently working as many people are working with it. It is very easy to make one at a reasonable cost. You may have a look at these links given below which may be helpfull.
You may also try these links given below.
www.blueroomelectronics.com
www.united77.com/products.htm
www.icprog.com
www.lancos.com/prog.html
OR
Try google search with keywords "JDM programmer" for serial port programmer or Pickit2 clone" for USB programmer. You'll find ample designs on the net......... Cheers
