Photomultiplier tube circuit
Vlad.
Full Member level 3
Full Member level 3
Bucharest/Romania
Hello guys, I am working with some R7600 MapMTs from Hamamatsu, and i try to read the dark current.
This is the circuit that I have proposed to use for this purpose. Can someone with experience look at this schematic?
I need to measure current about 2..20nA.
Thank you.
  • Output_Mapmt_v1.pdf
AD8009 is the wrong device. You'll use a CMOS or FET input OP with low input current.
By a second stage gain of 151, the input current range is limited to +/- 1.5 nA, so it won't work for intended pupose.
