Hello All,
I have a set-up which consists a photodiode(non biased set-up) -> transimpedance amplifier -> sallen-key band-pass filter -> anti-aliasing filter -> ADC -> digital lock-in amplifier. In analog amplifier section, I'm referencing all ground connections(except op-amp's VSS pin) to a virtual ground. Digital lock-in amplifier locks in to a ~980Hz square signal, sampling rate is 10 000.1Hz. Behavior is very good in normal room condition with curtains closed. Device is working as expected.
However when sunlight hits the photodiode (non directly) I get approx. 500µV shift to the results (depending on sunlight intensity).
I have made sure that:
- Photodiode is not saturating, also since photodiode is operated in non-biased mode, light response should be linear as possible
- Virtual ground impedance is not a problem, since I'm using a rail splitter which has approx <1 Ohm sink/source impedance. Also I have tried to use the real ground, but problem still exists.
- With DSP I have calculated average, min and max values from signal batch which DOES NOT change significantly (only +/- one LSB) when sunlight hits the photodiode.
I've been investigating this whole day and I can't think of any more ideas. So fellow forumers, all expertise, ideas and suggestions are welcome!
Thank you in advance!
