dannybeckett
Hi there,
I am building a lock-in amplifier, of which a quadrature phase shift section is required. I have constructed the circuit here:
https://www.tedpavlic.com/teaching/osu/ece209/lab1_intro/lab1_intro_phase_shifter.pdf
Which does work very nicely. I have chosen 5K1 resistors for the feedback, a 100K trimpot and a 3.3nF capacitor for the RC circuit. This gives me a range of about 500Hz to 100KHz at 90 degrees phase. The problem I am having is that at higher frequencies, the output waveform is somewhat distorted.
At 1KHz everything is OK:
https://snag.gy/yfcPO.jpg
At 80KHz the output waveform is somewhat distorted:
https://snag.gy/0wA5i.jpg
At each frequency I adjusted the trimpot to achieve a 90 degree phase shift. I am just wondering what could be the cause of this distortion? Could I be running into bandwidth issues with the op amp I'm using? (OPA4137)
Thanks for any help,
Dan
Dan
