Terminator3
Advanced Member level 3
First some links:
https://en.wikipedia.org/wiki/Phase-Comparison_Monopulse
And in book i am reading says: "-90...90 deg unambiguous angular position for antenna spacing λ/2".
For example:
1 - we have two antennas with spacing λ/2, book says this gives unambiguous angular position. It looks right, because if signal comes from -90 deg, then it arrives at first antena with phase Phi, and second antenna with phase Phi+180 (λ/2). When signal comes from +90 deg, second antenna would be Phi, and first antenna Phi+180. So relative phases would be -180 deg to +180 deg (Phi-Phi-180=-180 deg to Phi+180-Phi = 180 deg)
2 - Real objects can move in two directions. It is well known, that for moving objects IQ mixer can be used, then we can sense direction (+/-90 deg shift for different directions).
And here what i am curious about:
Let's go back to monopulse receiver with 2 antennas. Assume signal comes from some point, that gives phase Phi on first antenna and Phi+90deg on the second antenna. But then i realized, that it is the same, that having IQ mixer "in air". The problem is, if object approaching, then that would be +90deg, and when the object goes away, that would be -90deg. There are no longer unambiguous angular position, because it will depend on movement direction of the object.
There is nothing written about this phenomenon in my book or articles i found. I guess there must be not only phase monopulse receiver, but also an IQ receiver to detect direction of object, then fix somehow this phase "mirroring"? Is it necessary to have IQ receiver to make angle measurement unambiguous using phase monopulse?
Thanks!
For example:
Thanks!
