patelvivekv1993
Newbie level 6
- Joined
- Feb 21, 2014
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 81
i want to design a Phase lock loop using microcontroller with memory block method(i.e not using hardwired XORing)....i know its somewhat hard and complicated so i wanted to start by starting with small small steps........
i am using PIC18F4550 right now i have configured its ADC with TAD as 64Tosc and acquiring time as 2Tad and i am using 48Mhz crystal so calculating with that values i think my sampling freqeuncy is 250KHz ??????
i am using mikro c Pro for PIC and proteus for simulation.......
Now i wanna know that 250KHz samling frequency means that if i provide a 250KHz sine wave to the analog channel my all output must be 0????(or nearer to 0) as at that time the sampling would be done...
i know that it will be also the case for double and half frequency....but thats not my concern right now....
what i wanna do right now as initial step towards PLL is find out whether the signal supplied to the controller is of a certain frequency or not....so is my logic correct???
becuase i have simulated the above with mikro c and proteus and i m gettting the wrong results i.e instead of getting 0 at 250KHz i am getting it at 250Hz
i am attaching my mikro c project as well as proteus file and writing the code below
and if someone knows or has done PLL can u please give me some deep insight on actually how it is done using controller????
please help me here.....
thnx in advance.....
//Memory Card Chip Select Connection
sfr sbit Mmc_Chip_Select at RB2_bit;
sfr sbit Mmc_Chip_Select_Direction at TRISB2_bit;
unsigned char filename[] = "vivek.txt";
unsigned char error;
unsigned int temp;
double adc_value,voltage;
unsigned char tagline[] = " hello i am vivek using mikro c ";
unsigned char voltage_Log[7];
void main()
unsigned char ones,point_ones,point_hundreds,newline='\r\n';
TRISD =0x00;
ADCON0 = 0b00000001; //A/D Converter Power Up
ADCON1 = 0x00; //All Analog Channels
ADCON2 = 0b10111110; //Right Justfied and Slowest Clock for better accuracy
ADC_Init();
SPI1_Init();
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV64, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
error = MMC_Init();
while(error == 1)
LATD=0xff;
error = MMC_Init();
LATD =0x00;
MMC_Fat_Init();
SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV4, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
Mmc_Fat_Assign(&filename,0x80);
while(1)
adc_value = ADC_Read(0); //Read Temperature from ADC
voltage=adc_value*5/1023;
ones = voltage/1;
ones = ones | 0x30;
temp=voltage*10;
point_ones = temp%10;
point_ones = point_ones | 0x30;
temp=voltage*100;
point_hundreds = temp%10;
point_hundreds = point_hundreds | 0x30;
voltage_Log[0] = ones;
voltage_Log[1] = '.';
voltage_Log[2] = point_ones;
voltage_Log[3] = point_hundreds;
voltage_Log[4] = 'V';
voltage_Log[5] = '\r';
voltage_Log[6] = '\n';
Mmc_Fat_Append();
//Mmc_Fat_Write(tagline,sizeof(tagline));
Mmc_Fat_Write(voltage_Log,sizeof(voltage_Log));
