Does anyone have any idea how can I measure the phase difference between two digital signals? Nothing special so far, but one signal is a PECL 200Mhz clock and the other is a trigger signal (low to high edge) which may appear anywhere between those two raising edges of the clock signal...and I want to know where. I had some ideas ( track and hold circuit followed by an ADC, but I haven't found a fast enough ic). An discrete track and hold circuit with a switch which charge/discharge a cap from the clock source continuously untill the trigger occur is also a dream, because the switch must turn into off state in a period <1ns to preserve a acceptable error between the ideal point and the real point. The fastest switch I found have toff=5ns...which is the period of my signal....so....any ideas? Thx.
