period of sum of signals
Bhuvanesh123
Full Member level 1
Singrauli, India, India
i am reading signals and system by oppenheim.There they shown way to found how to find period of a signal,but did not show to find the period of signal when it is in sum like x(t)= sin5t-4cos7t .Here i can find period of individual signal(i mean sin5t and cos7t) but with that how can find period of x(t).Thank you
That solution says the resulting period is the Least Common Multiple (not a GCD) of the two periods of 2pi/5 and 2pi/7.
This basically means that if we pick a t then for some LCM of the periods of both signals there will be a time N*t that the signals will be the same as at t.
Using some simple counting as an example:
1 2 3 1 2 3 1 2 3 1 2 3 1 2 3 1 2 3       123 repeated (period of 3)
1 2 3 4 5 1 2 3 4 5 1 2 3 4 5 1 2 3 4 5   12345 repeated (period of 5)
S                             R
One result (which may not be the smallest) will be multiplying the periods of each to find the period of the combined, i.e 3*5 = 15
Yes, it's least common multiple when you ask for period. It's also GCD in frequency.
Ah, yes:idea:. We were looking at things from the opposite sides of the "coin". :)
