In standard JI CMOS the substrate will be tied to most negative
potential (perhaps some very special cases to the contrary).
Any P+ in P- substrate will have an ohmic ground connection.
You would have to provide the current, to establish any
voltage difference, and substrate current is generally not a
good thing.
A twin-well technology or SOI, would give you additional
freedoms at additional cost.
Is it the case that your NMOS4 has a substrate at different potential than ground?
if so then you have to use local dedicated substrate not the global P sub. For that you can use deep N-well. It is the layer we use in the circumstance where the body of the mos is connected to the different potential tank vdd or ground.
Uses dnwell layer inside that a nwell + guard ring and inside guard ring NMOS4. Now you can connect this guard ring to any desire voltage you want to.
