I am having issues trying to simulate the PIO example using the below command which was mentioned in the pg156 manual for ultrascale_pcie_gen_3 from Xilinx.
I am able to see the waveform and add the waveforms. However to have a link_up signal I had to wait for sometime until my simulation ran upto 180ns.
I would like to test the other testnames as mentioned in the manual. Could you tell me what command name can I use in the tcl console to get other simulation "testnames" ??
when I run the demo_tb.exe I get invalid command name. I cannot find any demo_tb.exe file in the project folder. When I do relaunch_sim it runs sample_smoke_test0 sample file by default. So I was able to replace the default code with other code and then get the simulation running. However the demo_tb.exe command was found in my project.
Yes you can run with different tests by replacing the default code with different test name. But unfortunately I could not find the demo_tb.exe in project dir or get it running.
Then start looking for errors in the compilation Vivado tends to get a compilation error and continues on until it gets to something that breaks the tools.
Unfortunately I could not change find the error or the demo_tb.exe. The alternative was to change the testname to one of their sample test programs and get the waveform.
