David_
Advanced Member level 2
- Joined
- Dec 6, 2013
- Messages
- 573
- Helped
- 8
- Reputation
- 16
- Reaction score
- 8
- Trophy points
- 1,308
- Location
- Sweden
- Activity points
- 12,242
Hey.
I'm building a lab power supply, I've finished the schematic but when I begun to route the PCB found my self in a inferno of wires crossing over each other. I started out using all SMD but in the end I had to use some through-hole just to get the layout done, the power supply has a transformer 230V/28V-0-28V 0-12V, the 0-12V winding is being used to supply a micro-controller and some other digital stuff and the 28V-0-28V feeds a regulator circuit. Its is controlled from the uC but the analog control circuit calls for multiple regulated voltages, these voltages will have to reach pretty much all over the board and there are both positive and negative voltages. I like the idea of only using SMD but I ended up the SMD bypass capacitor for various ICs with a small through-hole cap just to use the legs to pull up the relevant voltage from the bottom layer, the top is occupied everywhere and does not allow for the voltage rails to be routed and i ended up slathering the bottom ground-plane with voltage rails going like a maze to get them to all the places they need to be. I would feel ashamed to show anyone the finished layout, looks like it has been done by a drunk squirrel but I'm really rushing to get a working prototype going, all experience I have comes from my own DIY circuits and if nothing ells I've conclusively proved that this type of sloppy routing is from start to end a bad idea. But I wonder what the performance impact could be, I'm sure I've created a ground-loop de loop paradise and I thinking of dumping this design and make a new relying on cables to jumper voltages over the board. But i would like to ask a few questions that i have been reasoning about for some time.
There are a I2C bus that stretches over the hole board but aside from that is there any down side to have cables running over the board with steady voltages?
How about a I2C bus going from one IC to the next, to the next, to the next, in the and jumping pretty much all over the board?
Is there any point in using one of those mini coax cables? I have no idea what there name might be but a coax that has a outer diameter of 3mm or something.
I'm prone to use 1206 resistors and capacitors instead of 0805, they are i little easier to solder but I like having the gap between pads to route small traces, are these "under 1206 packages routes" a bad idea or is its just fine?
What about routing between two holes of a through-hole capacitor?
I don't like the idea of using lots of vias to for exampel go from top to bottom, straight line 1cm and then back up to the top again. There would be a lot of that down and under strips, but would it have any impact on the circuit function? Enough to care, its a linear power supply with a isolated digital uC board. I don't know but i imaging that in such a low frequency situation that kind of board layout would have marginally noticeable consequences.
If routing happens to produce cuts in a ground fill as to produce a kind of maze with many narrow passages, is it a good idea to use vias in remote areas of the maze to areas of ground fill on the other layer with wider openings in its ground fill?
Is it a odd practices to occasionally use a through-hole resistor instead of a SMD motivated only by opening up and sneak traces under it?
Regards
Regards
