ivenzar
Member level 2
Hello,
We are using a converter with two galvanically isolated grounds. Each of this circuit ground is referenced to an isolated power supply ground. (Power supplies have the 3rd/safety terminal at the input connected to earth ground).
Additionally, topology control is performed by a PC through USB bus. PC power supply input is also connected to the earth ground by 3rd/ safety terminal.
Can we have any problems with the earth ground? All power supplies are at the input referenced to same ground. Is USB isolated?
Thanks.
Thanks.
