Hello I am Nandeesh from India. I am doing my project PC based oscilloscope using PSOC. i want data logger software to plot the waveforms in PC. So any one knows any free datalogger software to plot the graph. i have already done with the code. So please help me in this matter. I left with short time.
Live Graph
Plot and explore your data in real-time!
LiveGraph is a framework for real-time data visualisation, analysis and logging.
LiveGraph is free and open source. It is available under a BSD-style licence
with the requirement that any copy acknowledges the original product and its developers.
If you are planning to use C# or dotnet....the best that i found was zgraph with documentation....I used it it really works.... and many options are there too.... **broken link removed** A flexible charting library for .NET - CodeProject
Thank you sir for your reply. I followed the link you have attached and downloaded the link. But I am not finding any window only read only files I am getting in the zip folder. Please suggest me the steps to download the software.
Atlest I know about Z-graph...it will work on low sampling rates.... it is based on what is your sampling rate ....if you are using UART kind of thing for your sampling then it will be possible but I am doubt full about the audio port or USB....there is a way where you can have time slotted capture of data and then representation on the graph application....I never tried USB or audio port but tried with Serial Port in dot net frame work....it works
Here is a scrren shot of the application in which I had used the "z-graph" libarary in the application that I had developed for solar power analyzer .....
