ms1234
Junior Member level 3
I am designing patch array antenna.
For the 16 and 64 elements patch array antenna in Unii band, it is very fortune, I finished my work within a month. and VSWR is under 1.3 @ 5.1GHz - 5.8GHz.
But for 2.4GHz, I can't find a good solution. this is because all simulation tools that I have used give the result very different with mesurement.
So I use "cut and try" method to find out the solutions, and it easy to match all elements to 50 Ohms in UNII band.
But in 2.4GHz, simulation still give the result different with the pratical one,
but I need match all elements by 100 Ohms.
Simulation can't give a good result, "cut and try" can't do 100 Ohms.
Any body can help!
ms1234
Any body can help!
ms1234
