determine capacitance from y values in ads
You can check the attachment, hope will answer your question #2 & 4.
Then call this equation in Data Display after dragging the list.
Regarding passive 'lumped' value at your designated operating frequency, try this one. Transform ZL to ZLn
and try below guidelines.
1.always use ZY chart
2.always start from the load end to prevent confusion, then move upward toward gen
3.Move on constant R- G circle in such a way to arrive at the center of the chart.
4.Each motion will give you the value of a reactive element.
5.Moving on constant R yield aseries reactive element. and moving on constant G yield to ashunt.
6.The direction of travel on a constant R-G circle will determine the type of element to be used.
7.If the motion is upward it correspond to aseries or shunt inductor
8.If downward it correspond to a series or shunt capacitor
You can do this in ADS data display using marker on the smith chart, you can also write an equation under this environment to find the value of lumped element that you want, you need to read the Data Display documentation and you can find so much information that's really useful
This is just a guideline for typical problem, there's a lot and depend on your circuit.
Goodluck...
