Passing sbit address as function parameters on 8051
x_zoli
Full Member level 1
Brasov, Romania
8051 parameters
Hi all
Can anyone tell me how to pass sbit and/or sfr addresses as function parameters in Ke*il, so that later on I can assign values to those sbits or sfrs (more specifically port pins, or an entire port).
I am trying to write a set of LCD functions (HD44780 compatible) and make it a library. Using it as a library, I have to make it flexible to the level that the data port and control pins can be specified by the means of library functions. This is where my problem begins.
Thanks
nex
Member level 4
Member level 4
Tarnaveni, Romania
keil + function + sbit
Use a char variable for SFR, and use AND/OR to handle the bits :)
Cheers !
usbman
Full Member level 1
Germany
sbit-address 8051
SFR addresses and bits are not possible as params in Keil
See also the c51 manual
usbman
bobcat1
sbit 8051
Hello
Here is how to access an SFR using it's address C language
//Set Ptr to the address - if the SFR lay at address 99H :
#define sfr_test 0x099 //0x099 is the SFR address
void ChangeSfr(unsigned char *SfrData)
//Set the value of the SFR to 55H
SfrData = 0x55;
//Function call
ChangeSfr((unsigned char *)sfr_test);
I don't think you can use this methode to access a single bit !
regards
Bobi
ayan_m
Newbie level 6
Newbie level 6
sbit in keil
to pass bits as function parameters define the bit as an sbit at the beginning of the program and then use the same definition as the function parameter
e.g:-
sbit ACC_0=0xE0;
void a_func(ACC_0)
This works as long as the function calling is properly defined
This has been tried and tested in Keil(uvision 2)
ayan
usbman
Full Member level 1
Germany
passing sfr values in function in 8051
none of the above soulutions will work
params are passed in registers! in Keil
please check the asm output
usbman
