partial and dynamic reconfiguration
deepa
Full Member level 2
Full Member level 2
partial reconfiguration profile
what is the difference between dynamic and partial reconfiguration?
Dynamic means run time, while system is operative.
Partial means part of the resident resources are reprogrammed while other system areas are unaltered.
so with SRAM FPGAs, it is all dynamic reconfiguration or did i get that wrong???
Here are some simple / basic classification schemes:
* one-time configuration (e..g. using antifuse technologies) != reconfiguration (e.g., using SRAM or Flash memory cells)
* full-chip reconfiguration != partial reconfiguration (some regions of the logic array are selectively reconfigurable)
* static (only one configuration is used) reconfiguration != dynamic or run-time reconfiguration (multiple configurations can be downloaded one after another during the application lifetime)
In general, dynamically reconfigurable (also called run-time reconfigurable) FPGAs are SRAM-based due to their fast configuration memory access (read/write).
Examples of commercially available FPGAs that support both partial and run-time reconfiguration are Xilinx Virtex and Spartan Series (incl. the newer ones) and Atmel AT40K/AT94K (FPSLIC).
Hi,does Lattice and altera fpga have this function?
