Hi, so here's my problem , I've built an working smps , delivers loads etc fine but since i'm using for audio it's giving me this problematic output. My output is 90-0-90 VDC.I have two secondaries , two separate transformers each having a bridge rectifier and filter caps , also snubbers across the filter cap bank traces and idle voltage limit resistors across the 90-90 outputs.
both transformers are driven from a single half bridge consisting of two IGBT's driven by IR2110 which gets it's frequency and waveform from SG3525.
both transformer output literally have the same problem , when i probe with my scope into each transformers rectified output no matter whether between 90 to gnd or vice versa I get the same sinusoidal spikes.
I will have a good cam tomorrow I could try to take some screen shots.
I tend to to think that these spikes I see at output are the turn on and off moments of the half bridge switches , somehow the current entering the primary causes a spike.
or that one of my transformers maybe has an airgap in the core since it was taken from an older philips tv power supply but it's not the typical hv ferrite transformer for the high voltage CRT voltage.
Well I will do some more tesing tomorrow without that particular transformer and see what happens.
Meanwhile maybe you guys have some advice.
