Parameter array in Verilog
mwn1
Newbie level 3
Newbie level 3
is it possible to create parameter array in verilog? for example, anything like the following
parameter[`TOTAL-1 : 0] PARAM_ARRAY = {1, 0, 0, 2}
if it is not possible, what could be the alternative solution?
Thanks in advance
It's easy in SystemVerilog
parameter int PARAM_ARRAY[`TOTAL] = {1, 0, 0, 2};
If N has the value 3, PARAM_ARRAY[N] will have the value 2.
However in Verilog, you will have to pack all the elements into a single big vector.
parameter  [0:(`TOTAL*32)-1] PARAM_ARRAY = {32'd1, 32'd0, 32'd0, 32'd2};
If N has the value 3, PARAM_ARRAY[N*32+:32] will have the value 2.
hi dave_59,
thanks for you reply.
if i understood correctly, you wanted to mean in the last line is that
PARAM_ARRAY[N*32: (N+1)*32-1]
will have the value N-th number of the PARAM_ARRAY. so if N=3, then it will have 32'd2
please correct me if im wrong
You cannot have a variable expression for both the MSB and LSB of a range. The syntax I showed is called an indexed part-select. See 11.5.1 Vector bit-select and part-select addressing of the IEEE 1800-2012 LRM.
Reactions: mwn1
    mwn1
