fjpompeo
Advanced Member level 1
Which is the difference between paralleling bipolar transistors using emitter resistors without base resistors or base resistors without emitter resistors?
I'm designing a psu with 13,8V@25A that will power my HF radio plus charge a 13,8V 45Ah car wet battery, so what configuration should I use?
Positive regulation or negative regulation?
Regards,
Fernando - Call sign PU2PLL - Brazil
Regards,
