jokester4u
Junior Member level 2
can someone help me to generate parity with 8 bit of inputs parallel to parallel using state machine using vhdl code?
I have done serial to parallel converter
can someone fix for me ?
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity spc_state is Port ( clk : in STD_LOGIC; rst : in STD_LOGIC; d_in : in STD_LOGIC; ready : out STD_LOGIC:='0'; err : out STD_LOGIC:='0'; d_out : out STD_LOGIC_VECTOR (6 downto 0):="0000000"); end spc_state; architecture Behavioral of spc_state is type state is (idle, one, two, three, four, five, six, seven, eight, nine); signal pres_state, next_state : state; signal reg : std_logic_vector (9 downto 1); begin process (clk, rst) begin if (rst = '1')then pres_state <= idle; elsif (clk' event and clk = '1') then pres_state <= next_state; end if; end process; process (pres_state, d_in) begin next_state <= pres_state; case pres_state is when idle => if d_in = '1' then next_state <= one; else next_state <= idle; end if; when one => reg(1)<= d_in; next_state <= two; when two => reg(2)<= d_in; next_state <= three; when three => reg(3)<= d_in; next_state <= four; when four => reg(4)<= d_in; next_state <= five; when five => reg(5)<= d_in; next_state <= six; when six => reg(6)<= d_in; next_state <= seven; when seven => reg(7) <= d_in; next_state <= eight; when eight => reg(8) <= d_in; next_state <= nine; when nine => reg(9) <= d_in; next_state <= idle; when others => next_state <= idle; end case; end process; process (pres_state) variable temp : std_logic:='0'; variable temp2: std_logic_vector(7 downto 1):="0000000"; begin case pres_state is when idle => temp := reg(1) xor reg(2) xor reg(3) xor reg(4) xor reg(5) xor reg(6) xor reg(7) xor reg(8) xor reg(9); err <= temp; if temp = '0' then ready <= '1'; d_out <= reg(7 downto 1); temp2 := reg(7 downto 1); end if; when others => d_out <= temp2; end case; end process; end Behavioral;
