You didn't yet tell, what you want to achieve. I assume, that you want to drive a parallel printer from a PIC processor. That's easy related to the required interface behaviour. But there's also a software driver aspect. Which device do you want to drive? What's the data source? You should also clarify, which LPT interface lines are actually required in your case. Normally, the lines mentioned in my previous post should be sufficient.
Address 0x378 is a x86 PC thing. It's irrelevant for the PIC. For LPT specification details, you can refer to this site **broken link removed**
