Parallel port programming in c#(to control a led light)
Malli510
Newbie level 3
As i want control a led light
i attached it's +ve to D-0 and negative to ground pin in parallel port
the led glows when system boots up
and i have written my program in c#.net
as below
Code C# - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
using System;
using System.Runtime.InteropServices;
public class PortAccess
    [DllImport("inpoutx64.dll", EntryPoint = "Out32")]
    public static extern void Output(int adress, int value);
    [DllImport("inpoutx64.dll", EntryPoint = "Inp32")]
    public static extern int Input(int adress);
and i place my inpoutx64.dll in
C:/windows/system/
C:/windows/system32/
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace ConsoleApplication1
    class Program
        public static void Main(string[] args)
            int address = 888;
            int value;
            PortAccess.Output(888,255);
            value = PortAccess.Input(address);
            Console.WriteLine(value);
            PortAccess.Output(888,0);
            Console.ReadLine();
when i run the program it shows no error and runs fine but the led is not glowing
can anyone plz help ..me
thanks in advance;
thanks for the link but can you explain what's wrong in my code ,
it seems inpoutx64.dll is working fine but how does it link with hwinterface.sys file *(does it create's it own hwinterface.sys or do i need to download it )*
if i have hwinterface.sys file how to link it with inpoutx64.dll or do i need place it some where
https://obrazki.elektroda.pl/76_1341208219.gif
You need to put the driver file in your System32\Drivers folder. Make sure, if your using XP/2003 x64 Editions, to put the 64bit version there (hwinterfacedrvx64.sys) instead of the original 32bit version (hwinterface.sys)
See more **broken link removed**
even after placing hwinterfacex64.sys file in system32/driver/ folder the led is not glowing .... my program runs well and it shows no errors or warnings....
You are setting your output back to off before you are doing the console.read
try changing your main to this:
int address = 888;
int value;
//FF or 255 D0-D7 on
Console.ReadLine();
//00 or 0 D0-D7 off
Console.ReadLine();
as below
Code C# - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
using System;
C:/windows/system/
using System;
using System.Linq;
using System.Text;
    class Program
            int address = 888;
            int value;
            Console.ReadLine();
thanks in advance;
