Parallel pattern simulation failure in compressed mode
shalin mandiwala
Junior Member level 3
Hi all,
I want to know that in compression mode why i am getting simulation failure if i use parallel simulation?
As i jump to serial simulation, it is successfully passing the pattern simulation. What could be the reason? Does parallel simulation in compressed mode bypassing something because of extra decompressor/compressor logic added or what? Please help.
Thanks in advance.
No,its not design or setup error.Its an output mismatch error.
Simulator is displaying error like got ? expected 1/0. Serial simulation is successfully passing for all the patterns.Only parallel simulation is failing.
