Parallel NOR flash power supply design
tramu
Junior Member level 3
Dear Sir,
I want to calculate the power requirement of an NOR flash from micron.
IC requires two power supplies: VCC(core) & VCCQ(I/O).
I calculated the power requirement of VCC(core) from the data sheet as VCC(max) * ICCW.
I want to calculate the power requirement of the VCCQ(I/O) supply.
I am not able to get the data from the vendor.
How, do I calculate the VCCQ(IO) supply power requirement of a NOR flash.
Please find the attached datasheet for reference.
Thanks in advance.
Regards,
Thulasi
  • 208034_P33_65nm_SBC_64M_128M_Discrete_DS-1.pdf
Dear Sir,
Thanks in advance.
Regards,
Thulasi
well, this is not really the forum for that , but don't you need to calculate the io current by the rising/fallling time and the output load ?
Hi aruipksni,
How do i calculate io current by rising/falling time and the output load ?
Please help in this direction. Please share any document/link to read...
Regards,
Thulasi
Hi aruipksni,
Regards,
Thulasi
1/ from datasheet get rise , fall time - see which is the fastest (lower value).
2/ get you maximum output capacity of the flash , add it to all the connected devices input capacity - so you have the total load.
3/ from schematc check what is your max i/o voltage.
4/ use the simple formula i =~u*c/min(tr,tf), and multiply by number of dq pins + other ctrl pins.
so for example : for 2.5v power supply , 10pf, capacity, 5 ns tr you get 5ma/pin.
