PARALLEL MASTER PORT communication problem
bikashh
Full Member level 5
Full Member level 5
india
Hello Friends,
I am doing a project around PIC32MX675F512L in which I need to communicate with external RAM(IDT71V016SA) connected parallel. I am using "PARALLEL MASTER PORT (PMP)" for communication.
But when reading into a buffer from external RAM, all the locations gets filled with the last value being written in the write process. I checked the hardware but everything seem OK.
My code is as below:
mPMPEnable();
mPMPOpen(CONTROL, MODE1, PORT, INTERRUPT);
PMADDR = 0;
for (i=0; i<10; i++)
PMPMasterWrite(i);
buffer1=PMPMasterRead();
PMADDR++;
// PMADDR = 0;
buffer1 = PMPMasterRead();
PMADDR++;
Thank you in advance
Thanks for the reply,
Actually the code is like this,
mPMPEnable();
mPMPOpen(CONTROL, MODE1, PORT, INTERRUPT);//interrupt is disabled
PMADDR = 0;
PMPMasterWrite(i);//I is the value I am writing to external RAM
PMADDR++; // incrementing RAM address
PMADDR = 0;
buffer1 = PMPMasterRead(); //reading from RAM 1st location and writing to buffer1
PMADDR++;
Tried different ways but failed.
Thanks
mPMPOpen(PMP_ON | PMP_READ_WRITE_EN, PMP_MODE_MASTER_1 | PMP_AUTO_ADDR_INC, PMP_PEN_ALL, PMP_INT_OFF)
Post your full code and also the circuit showing interfacing of the external device to PMP port. What external device is interfaced?
