not with the transmitter you have mentioned......
I don't exactly understand you're specification. If a pwm signal with a period of 100 Hz is transmitted once per cycle, you get at best on or off state, but no pwm (pulse width modulation). You can transmit a 50 Hz squarewave (alternating on and off). You can assemble individual bits to a serial data stream by a shift register, but an unequivocal frame synchronisation must be added. So the resulting data rate will be somewhat higher than 1 kbps. And you have to consider the requirement of RF modules for balanced serial data. Manchester encoding could be used, but doubles the effective data rate.
In most cases, a microprocessor would be the lowest part count solution, but unfortunately requires programming.
P.S.: Perhaps you can give an example, what kind of information is carried by the "pwm" channels.
Yes, I expected something like this. So the next question is the intended change rate for each input? If you e.g. intend to transmit analog samples with a rate of 100 Hz for each channel, the overall data rate would go far beyond the said 1 kBaud of RF channel. The best way to get a fast reponse ist to transmit the analog voltages digitally (e.g. 8-Bt encoded), and to transmit large changes first. Ends up in using a microcontroller on each end of the RF channel.my actual need is to transmitt and recieve 8 analog signals
which pdf are you talking ... can you be more clear
