Papers related to MTCMOS , power gating, clock gating and low power IC design
dhawalkadao
Junior Member level 1
Here is the Paper I found on Low Power IC Design
sishir
Regarding Low Power IC design.pdf
The document use sent is very good. Thank you for that. please upload any related stuff. i'm looking for documents regarding low power design.i have got some documents regarding the same. i can share those documents
Regards,
Sishir
research235
Full Member level 6
Low Power IC design
hello sirshir
tell me wat do u want in Low power .. which exact doc ur looking for
suresh
sishir
Re: Low Power IC design
Good morning Mr. Suresh,
All the documents i have found till now discuss only about the static and dynamic power issues and nothing more than that. i'm looking for docs. discussing about multi-threshold, voltage islands, detailed clock gating, power gating and like wise. could you please help me out.
thanks for your reply.
Regards,
Sishir
cheelgo
Member level 5
Low Power IC design
I also very interested in the power related issue in digital or mixed-signal design.
turtleden
Junior Member level 3
Low Power IC design
I am reading some papers about low-power writen by A. Chandrakasan.
sishir
I see that he published most of the papers on low power. do you mind sharing them?
research235
Full Member level 6
hello sishir
I have many papers related to MTCMOS , power gating and clock gating .. i will upload them for u
suresh
Added after 2 minutes:
MTCMOS sequential circuits by anantha chandrakasan
research235
Full Member level 6
clock and power gating with timing closure
suresh
research235
Full Member level 6
clock gating and its application to low power sequential circuits by M pedram
turtleden
Low-power CMOS digital design
