PAPER REQ:Wide band asymmetric coupled-transmission-line mag
Needbias
Full Member level 1
Wide band asymmetric coupled-transmission-line magic-T and sum-difference circuit
Gruszczynski, S.;
Microwaves, Radar and Wireless Communications, 2004. MIKON-2004. 15th International Conference on
Volume 1, 17-19 May 2004 Page(s):162 - 165 Vol.1
Abstract:
A novel broadband 3-dB/0/spl deg//180/spl deg/ coupler and a novel sum-difference /spl Sigma/-/spl Delta/ circuit, consisting of a coupled-line multi-section asymmetric 3-dB directional coupler and a coupled-line multi-section phase compensation network, are comprehensively theoretically and experimentally reviewed. The multi-octave bandwidth of such networks can be achieved by increasing the number of coupled-line sections of both the asymmetric 3-dB coupler and the phase compensation network. An approximate computational procedure for designing such a network is proposed. Tables are given with example computational results for two and three section magic-T networks. An ultra-broadband (with bandwidth BW=10:1) magic-T has been designed manufactured and measured. The measured results are in a good agreement with the theoretical ones.
Re: PAPER REQ:Wide band asymmetric coupled-transmission-line
Here it is...
Regards
haadi20,
Thanks you very much.
best regards.
needbias
