Artlav
Full Member level 2
I'm working on generating a PAL video signal, and came across a certain ambiguity between the theory and the practice.
Specifically, the descriptions of the PAL signal, i.e. http://martin.hinner.info/vga/pal.html , specify that the vertical sync should be a sequence of 6 half-line short signals, then 5 half-line long signals, and 5 more short half-line signals.
However, in practice implementations for CPLD and MC only do 3 full-line long signals at the start of the frame.
And it seems to work generally fine on the modern TVs i have.
So, the question is - is that simple VSYNC version a proper solution?
What problems could there be from it, compared to the full one?
Some of the cheaper TVs have had problems locking on to the colour when i tried the simple version - can it be the cause? (color generation might also not have been up to spec).
