suryakant
Member level 5
code composer structures
I am working on Code composer for TMS320.
I ve structure in the code similar to following:
For TMS320, compiler aligns long int to next even address. So to above structure it pads one more integer so that long int variable gets even address. (structure starts at even address)
This variable i am sending on serial port to other controller (freescale MC9S12C128) who has same declaration at its side. The application is developed in code warrior where long can be accessed at odd addresses also.
In communication, padded word gets transferred to other controller, which goes into lower Word of unsigned long of freescale controller..
What can i do is add dummy word in the declaration itself, but I am limitation on memory (RAM), so can't do that..
How to handle this situation?
I ve found work around by splitting long into two unsigned ints and accessing long by using long pointer... but thats not encouraging.... is it?
new definition is
Use of stucture - union did not help
typedef struct _abc
unsigned int x; // 1 Word
long int y; // 2 Words
}ABC;
ABC myStruct;
new definition is
typedef struct _abc
unsigned int x;
unsigned int y; // lower word of long int
unsigned int z; // higher word of long int
}ABC;
