ruben91
Junior Member level 3
hi, currently i'm working on a new pic, p18f1330. bt previously i was using p18f4580 and my coding works fine, but wen i convert it to port in p18f1330, its not working, pls help..my project is using ultrasonic hc-sr04 sensor. whereby the distance measured will be display in hyperterminal and LED wil blink at diferent rates.. now i port it to p18f1330, wit jus led blinking and nt dispalying in hyperterminal, but now its not fuctioning, please help
i'm using mplab ide, c18 compiler and pickit2
p18f4580 code
p18f1330 code
p18f4580 code
#include <p18f4580.h>
#include <delays.h>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#pragma config OSC= HS
#pragma config WDT=OFF
#pragma config LVP=OFF
#define Trig PORTBbits.RB3
#define Echo PORTBbits.RB2
void T0Delay10us(void);
void uart(void);
void Call_Init_PIC (void);
void sendPulse(void);
unsigned int distance ;
unsigned int time;
unsigned f,b;
void main(void)
TRISDbits.TRISD0=0;
Call_Init_PIC ();
uart();
while(1)
TMR1H= 0;
TMR1L= 0;
sendPulse();
while(Echo == 0);
T1CONbits.TMR1ON = 1;
while(Echo == 1);
T1CONbits.TMR1ON = 0;
time= TMR1H;
time= time<<8;
time= time|TMR1L;
//time = (TMR1L + (TMR1H<<8));
distance = time/28.8;
f=distance/10;
b=distance%10;
printf("\r\nDistance = %d.%d cm",f,b);
PIR1bits.TMR1IF=0;
Delay10KTCYx(255);
if(distance>=0 && distance<=250)
LATDbits.LATD0=1;
else if(distance>=251 && distance<=500)
LATDbits.LATD0=1;
Delay10KTCYx(25);
LATDbits.LATD0=0;
else if (distance>=501 && distance<=1000)
LATDbits.LATD0=1;
Delay10KTCYx(25);
Delay10KTCYx(25);
Delay10KTCYx(25);
LATDbits.LATD0=0;
else
TRISBbits.TRISB3=0;
TRISBbits.TRISB2=1;
void uart(void)
TXSTA=0B00100000;
SPBRG=32;
TRISCbits.RC6=0;
RCSTAbits.SPEN=1;
Trig=0;
Delay10KTCYx(255);
Trig=1;
T0Delay10us();
Trig=0;
void T0Delay10us()
T0CON=0x08;
TMR0H=0XFF;
TMR0L=0XCE;
T0CONbits.TMR0ON=1;
while(INTCONbits.TMR0IF==0);
T0CONbits.TMR0ON=0;
INTCONbits.TMR0IF=0;
p18f1330 code
#include <p18f1330.h>
#include <math.h>
#pragma config OSC = INTIO2
#pragma config WDT = OFF
#define Trig PORTBbits.RB1
#define Echo PORTBbits.RB0
unsigned int time;
void main(void)
TRISAbits.TRISA0=0;
Call_Init_PIC ();
while(1)
TMR0H= 0;
TMR0L= 0;
sendPulse();
while(Echo == 0);
while(Echo == 1);
//Delay10KTCYx(255);
time= TMR0H;
time= time<<8;
time= time|TMR0L;
PORTAbits.RA0=1;
else
TRISBbits.TRISB1=0;
TRISBbits.TRISB0=1;
Trig=1;
T0Delay10us();
Trig=0;
void T0Delay10us()
T0CON=0x08;
TMR0H=0XFF;
TMR0L=0XCE;
T0CONbits.TMR0ON=1;
T0CONbits.TMR0ON=0;
