The code as you have mentioned will be in mikroc, please read microc user guide
---------- Post added at 09:33 ---------- Previous post was at 09:32 ----------
main component:
pic16f877a
oscillator
flow sensor
power supply
matlab
mikroc compiler
---------- Post added at 09:36 ---------- Previous post was at 09:33 ----------
From here i can see that you have to use serial interface to PC, if you use 18F, you will have the alternative of USB interface, which will be much faster. The code in the microcontroller will just do the conversion and throw them to the PC. Most work will be done on GUI to interpret the data
---------- Post added at 09:37 ---------- Previous post was at 09:36 ----------
