Oversized ferrite core - is there any problem?
R
red_alert
Newbie level 1
Hello,
Basically, I want to build a two stage buck converter as a charger for a (solar) battery string.
I want to build those two inductors using some torroidal iron powder cores. I still didn't finish the calculations so I wonder if there's any problem if I'll buy some larger torroidal cores as theoretically needed?
Same question about a ferrite core (double E) for a HF transformer in a pure sine inverter: may I use a larger one? I mean, if a ferrite core could be used for a 5kW buck converter, may I use it for a 500W one?
The (greater) price it's not a problem, I just want it to stay cooler.
Thank you very much for any oppinion.
You can, but your calculations should be aware of core losses and leakage inductance.
Actually, I'm trying to build a 2kW charger (24V / 80A output). Could you recommend a suitable iron powder torroidal core (material/physical dimensions)?
Are these **broken link removed** cores a good choice?
you can use.but you have to provide more current to produce flux.Also core losses and leakage inductance will increase.
That means I have to use more turns (to multiplicate both primary and secondary calculated turns)?
LATER EDIT:
I've did some calculations using a software calculator and, for a given ferrite core (E71 from Ferroxcube), the core loses was about 6 watt or something (that was for a 4kW pure sine inverter).
So I guess it's not a big problem to get higher loses (12-15 watt) using a larger ferrite core. And if I'll use thicker Litz wire, I could minimize the copper loses too.
Am I missing something??
