Oversampling / Skew compensation - VHDL
The_Dutchman
Member level 1
Member level 1
Hello,
For my master thesis I'm using a transceiver (fancy serializer) that has a 64-bit wide TXDATA input port that gets serialized from bit 0 to 63 on the rising edge of TXUSERCLK2.
However there is skew between different transceivers (PCB track lengths etc) and I am trying to compensate this skew misalignment by oversampling and placing the right amount of 0's in front of the data.
So e.g. if this is the output of 4 transceivers (started at the same time)
0000000011011001110 (add 0 zeros)
0000001000101010001 (add 2 zeros)
0000010000001010001 (add 3 zeros)
1001011100111111000 (add 8 zeros)
To increase the resolution I also use oversampling, so if the oversamplingfactor is 2 then TXDATA(1) & TXDATA(0) have to stay TXNEEDTOSEND(0) and so on.
I'm really stuck with this because I have written code (attachment) that does what I need, but does not synthesize and using a switch statement will be very very very much lines of code. I'm thinking I'm just overlooking the simple solution here, could someone maybe help a hand ?
Thanks in advance,
  • SkewComp.zip
Hi from the synthesis POV i can also say that this code would not be synthesizable. For a quick analysis as to the other best possible option you could use a linting tool if you have like spyglass. This construct would show an error and you would know how best to implement it.
Reactions: pdude
    pdude
It looks ok to me...
The synthesis tool probably doesn't like to have vector ranges defined by variables or signals:
Code VHDL - [expand]
TXDATAOVERSAMPLED(upindex downto lowindex) := (others => '0');
TXDATA <= TXDATAOVERSAMPLED(oindex+63 downto oindex);
