bianchi77
- Joined
- Jun 11, 2009
- Messages
- 1,313
- Helped
- 21
- Reputation
- 44
- Reaction score
- 20
- Trophy points
- 1,318
- Location
- California
- Activity points
- 9,442
Guys,
I have OV7670 module and STM32 dev board,
I'm confused on how to connect the port of STM32 and OV7670 at the module because of the name of the port on OV7670 is different with in STM32 code,
anyone has experience ?
thanks
The code :
the port on ov7670
thanks
The code :
Module Pin Name | Description | STM32 end pin connections |
SCCB_SCL: SCCB clock: PB10 I2C2_SCL
SCCB_SDA: SCCB data: PB11 I2C2_SDA
CAM_VSYNC: Frame Sync: PA0 external interrupt 0
CAM_HREF: FIFO: PB7 GPIO
CAM_WEN: FIFO write enable: PD3 GPIO
XCLK: CMOS sensor master clock: PA8 MCO output
CAM_RRST: FIFO read address reset: PE0 GPIO
CAM_REN: FIFO Chip Select: PD6 GPIO
CAM_RCLK: FIFO read clock: PE1 GPIO
FIFO D0 ~ D7: FIFO data output: PC0 ~ PC7 GPIO
the port on ov7670
