What modifications should I use in this VHDL code:
in order to make it run on Spartan 3E Starter kit?
The above code has been written for Nexys2. If I change only the nexys2.ucf file to correspond to the the Digilent Spartan 3E will it work? Should I make any other changes?
From what I saw at a glance it looks like all the code is synthesizable behavioral RTL and should only require a new UCF file to assign the pins to the equivalent locations on the Digilent board.
The only issues might be the size of the part if the starter board is a smaller FPGA or if there isn't an interface available or the correct clock frequency on the starter board.
If the part is too small you'll either have to get a different board than the starter board or have to sacrifice features/functions in the design until it fits, i.e. change the VHDL code until the design is small enough and still does something useful that you need. If you can't remove anything from the design then you'll need a bigger FPGA.
I have send around 10 e-mails to different stores/web stores/electronics stores, nobody sells this kind of cables. I will keep trying however. But I thought some one here could give directions..
