ysh
Newbie
Hello,
I found some problem while building the module, and I can't understand it.
So I post the error on this forum.
dir value is not only defined as an integer in the module code, but also entered as an integer.
However, in the output file, it has a value in between.
This problem is solved when i change the code from V(e,b) <+ 0.001*dir; to V(e,b) <+ dir;
Can you point me to why this is happening?
Thank you.
Thank you.
