Output a VHDL Floating Point through Spartan 3AN
Mohammed Sheere
Newbie level 1
Helloo every one,
I'm working on a VHDL project, where i need to output a small (about 10 sec) audio file from Spartan 3AN board. I'm using ISE Xilinx 14.1.
i have the audio file, i did decompressed it and got the samples that i need with the size of each sample and i know the rate of outputing those sample to get the right sound. I even got all the voltage values of those samples.
All what's left is storing those values in a RAM and output them through the audio jack built in the board.
the Problem is, all those voltages values are ranging from -5.0 to 5.0 , and most of them have floating points like (-2.246821). i looked up in the internet and tried to find a solution on is there any floating point packages and i found this site **broken link removed** , BUT i don't know how to make them WORK !!!
IF anyone can please provide me with the steps of how to make those packages actually work, and make them give me the ability to actually use the (float) type deceleration in my design so i can output those voltage value in a FLOAT type , Please Help me !
ads-ee
Super Moderator
Staff member
USA
You don't need to output floating point, I'm pretty sure the DAC that the board uses doesn't take in something like IEEE 754 (floating point). I also highly doubt the DAC accepts fixed point data either.
Usually DACs either take in offset binary or 2's complement binary. So what you want to do is scale the values of -5.0 to 5.0 to the -(2^N) to (2^N)-1 range (N being the bit width of the DAC). So what you want is a multiplier and truncate/round off the least significant bits to obtain N-bits that are sent to the DAC.
