The project aims at the design of a fully-differential OTA to be used as a unity-gain buffer
in switched-capacitor filter applications. The expected load is 1 pF on each side as
shown below. The amplifier is required to accommodate a maximum swing of 3 V differential-
peak-to-peak running at 40 MHz and applied to the input of the amplifier. OTA’s
open-loop gain must equal or exceed 64 dB. The circuit operates from a 1.8 V supply
and can use no more than 0.5 mA. The requirement on third-harmonic distortion to be
below -60 dBc (i.e. the third harmonic signal at the output is 60 dB below the fundamental).
You can assume having an ideal reference current and you are supposed to design
the current mirror biasing circuit to supply the current source transistor in the amplifier.
Recommended Steps for the design are:
1- Choose the right topology
2- Translate design requirements into circuit specifications
3- Design the OTA and the CMFB amplifier
4- Verify circuit performance.
**broken link removed**[/img]
